hi expert
i saw the following data in our datasheet.
Q1: if i use 6.8KΩ to pull up to 3.3V voltage supply.(it means external pullup current is 3.3V/6.8KΩ=485uA). what the range of Vol(fault)?
Q2: could you share the internal block diagram of FAULT pin.
thanks
