Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
BQ24735EVM-710: BQ24735EVM-710
Part Number: BQ24735EVM-710
Hi Sir/Madam,
We are selected one of the battery in our design, battery is comprised of seven (7) Lithium Ion rechargeable 21700 cells, assembled in a 7 series / 1 parallel (7s1p) design.
so, We need to know which charger IC you will suggest for our application.
Mani J
  • Hello Manikanta,
    Thank you for reaching out. I have a few questions about your required parameters for the battery charger IC:
    What is the Input voltage/current?
    What is the charging voltage/current?
    Do you need standalone or I2C controlled?
    Here is a link to the list of all of our available battery charger IC's: Battery Charger IC's
    Christian.
