Other Parts Discussed in Thread: TPS922052, TPS922053, TL431
Hi Team,
Could you please kindly help to check if TPS92200D1 could support input =13.5V and output=13.2V, the output current is about 300mA~500mA. And what is the limitation for the value of input voltage-output voltage? Customer would like to use this device to drive an camera LED, if there has other suitable device recommend here? The end equipment is smart lawn mower. Thanks a lot for your support to check.
Best regards
Jie
