Other Parts Discussed in Thread: TUSB1146, TPS65987D,
The topic is locked. Open a similar one.
I can't download the files from the link https://txn.box.com/s/l4i4tp9f67dg9ylcqt3ykkjqn5djlc5n.
Could you post it again? Thanks!
Hi Zheng,
Thanks for reaching out. Here's the .pjt file for the TUSB1146 EVM.
Shane
Hi Shane,
Thanks for the quick response.
What's the main difference between TUSB1146 and TUSB1046?
I'm going to use the mux/redriver with TPS65987D to implement a DP alt mode + USB 3.1 on the source side. Looks like TUSB1146 and TUSB1046 are both doable. Could you suggest it?
Hi Zheng,
The main difference is that the 1146 has adaptive EQ. This is a feature that allows the 1146 to find the best EQ setting for the signal path you connect to it. I recommend using the 1146 if you want this feature.
Could you give me the TUSB1146EVM design files? Thanks!
Please see the schematic and layout files below:
Let me know if you need anything else.
Shane
