Hi Team,
My customer use TPS7A85A as adjustable mode, but their connection have some problem, could you help me check if below connection is workable?
Output setting as 1.8V, and feedback connect a 9.68k ohm, using internal 12.1k ohm + 9.68k ohm as resistor divider as below. (Please ignore input 1.4V and output 0.9V, suppose input is 2.5V and output is 1.8V). all ANY OUT voltage setting pins are floating (unused).
Roy
