Part Number: TPS25730
Hi team,
Customer is evaluating TPS25730 using our EVM.
They set Minimum Voltage Configuration to 9V by ADC1, and Maximum Voltage Configuration to 20V by ADC2. So they think that this would only get 9V~20V voltage pass through TPS25730.
When 5V get input, there will be no voltage pass through TPS25730. However the EVM test shows that 5V could still pass through TPS25730 to PPHV.
Could you help comments why this happen and if we could block the voltage out of the setting range?
Thanks and Best Regards,
Will
