Good day, colleagues,
My customer wants to use the LMG1210 with eGAN MOSFETs for power stage in a buck DCDC topology.
They need to do is sensing the inductor current for a current mode DCDC converter. Do you have some application or recommendation? I think that I maybe can use the DCDC output, so the high side sense resistor is at common mode voltage about 18V. I am going to aim at about 300…500kHz. So, the solution needs to be able to work in such a buck DCDC.
Thank you,
Daria
