When using in CV mode, is it only BOOT?
Because design information is not found in the datasheet.
Aloso, sinse When used in CC mode, is it BUCK-BOOST?
It's a multi-topology part so you can use it with different topologies for CV and CC.
Thanks Tuan
thank you for your reply.
Is it correct to understand that you can BUCK-BOOST in CV mode?
If you check the datasheet, it says the following:
「In CV mode, TPS92682-Q1 can be programmed to operate as two independent or dual-phase Boost voltage regulators.」
Can you please give me your requirement in a block diagram. I want to understand what you are trying to do first before I comment here.
Thanks Tuan
Yes, you can operate it in 2 independent CV Boost mode as you in the block diagram.
Thanks Tuan
