Hi Team,
One of my customer is using TPS3808 for their design & they have raised the queiry related to Ct calculation formula.
As per datasheet, foprmula is given as
Now as per the formula if we use 131pF in design then reset timing is 1.25mS so if we consider the statement that Ct >= 100pF is wrong. If we use 100pF in design then reset timing will be well less than 1 mseconds, can you help calrify why formula is not matching with the mentioned capacitor values?
Mitesh
