Hi Team,
Does the LP5890 support a single LED control for turning on/off?
Or it need to control LEDs by banks?
Is there any document with detailed information about this operation?
Thanks.
Hi Team,
Thanks.
Hi Peter,
which application are you using LP5890? real project or advanced research? how much LEDs do you need to control? since we have some reference design and I hope that can help.
yes, each LED can be controlled individually by PWM dimming and the global brightness and white balance can be controlled by analog dimming.
details are provided in the datasheet chapter ' 8.6 PWM Grayscale Control'
BR
Monet Xu
Hi Sir,
Due to the project being in a very early stage, no information can be shared with you!
project is in the display-related product department.
FYI.
