Hi Team,
When customer asks for Oring MOS, there are 3 questions here:
- What's the difference between -1 and -2? Seems the only difference is the charge pump position.
2. What's the key technical point between high-side and low-side? Seems high-side device's voltage stress is positive, and low-side device's voltage stress is negative, right?
3. What's the difference between Hot Swap and Oring MOS? Whether the Hot Swap integrates more function into basic Oring MOS?
