Other Parts Discussed in Thread: TPS61080, TLV61046A, TPS61046
Hi Team,
What is the recommended replacement for the TPS61080DRCR?
-Jared
Hi Team,
-Jared
Hi Jared,
thank you for using the E2E forum.
Due to a public holiday this Thursday and Friday the expert of this device is out of office.
Please expect a reply beginning of next week.
Stefan
Hi Jared,
The device TPS61080DRCR is not obsolete, you can still place an order and get them produced.
Right now, there is no P2P replacement for it.
Please tell me your input and output conditions and we can promote other solution for you.
Fergus
Hi Fergus,
Thank you for the insight. Why isn't the product folder available then? I don't have specs for the application. I just want to know which device we would want a customer to look at instead of the TPS61080DRCR since it does not have a product folder.
-Jared
Hi Jared,
The device is unreachable on TI.com because it is not open for any new design.
For ones used it before, it would be the same including supporting and supplying.
Please see the attached datasheet file.
When designing new project, we recommended to use TPS61046/TLV61046A,whose spec is almost same with TPS61080.
please check if this fit for the customer's application.
Fergus
