TPS7B87-Q1: TPS7B8750
Part Number: TPS7B87-Q1
Hello E2E member,
I am simulating TPS7B8750 with spice model which I downloaded in the TI Website. I am using Altium for simulation. The problem is that the output voltage is about 15Volt when I supplied 16Volt into Input pin. As I expect, Output voltage is 5V because this LDO is 5V fixed output. What did I do wrong?
Sheet3.SchDoc
