Part Number: TPS7A39
Other Parts Discussed in Thread: TPS65131
Could you recommend me a simple input voltage regulator with symmetrical output? I will use it to generate a +/- 12V voltage for the design of a wallbox. Some time ago, I used one of your voltage regulators TPSxxx classified as an LDO, which only required a single 5V input and with a simple resistive divider for the FB signal, it could generate a +/-Vset output. I did use it, and it worked perfectly, but I don't remember the part code, and I don't have access to the previous design. Could you recommend me one?
