Part Number: TPS62823
Hi team,
Minimum value of resistor divider R2?
Specifically, is it OK R2=10kohm?
Goto
Hi team,
Goto
Hello Goto,
Thank you for reaching out,
We only specify the maximum value(120kOHM) for better noise sensitivity.
Yes, this is fine. Generally lower resistor divider values will have a slightly lower efficiency at the light loads.
Thank you & regards,
Moheddin.
