bq51013 data transmission between transmitter and receiver
Other Parts Discussed in Thread: BQ51013
Is there any possibility to bidirectional data transfer between transmitter and Receiver??
I am considering wireless solution for data communication , will there interference problem with data communication and coil??
Please suggest solution for wireless communication.
This is block diagram of which i am taking.
ravi shah
  • The WPC standard will not support TX to RX communications or bi-directional communications.
    Communications are from RX to TX.  At this time the TI bqTESLA products communication are limited to control of the power transfer.   Options for customer defined communications are not availability at this time.
  • Are the options of data transmission open for Bq51013? or can you suggest any similar chip for wireless inductive charging which also performs data transfer. Requirement for us as low as 100 bytes per second...
    Ajay
