Part Number: UCC28065
Other Parts Discussed in Thread: UCC28061
Hi
Is it possible to design a bridgeless PFC using UCC28065??
Or is there any IC that can achieve CRM bridgeless PFC??
Thank you
I found this article on the web that compares Semi bridgeless to interleaved PFC. It used the UCC28061 to accomplish semi-bridgeless. The UCC38065 has a similar control scheme and should would for this application.
file:///C:/Users/a0799388/Downloads/Choosing%20Between%20Semi-Bridgeless%20or%20Interleaved%20PFC%20907PETOloughlin.pdf
I do recommend that your read the article however. There are benefits of interleaving over semi-bridgeless that may have you consider designing for interleaved instead.
