Part Number: LP5907
The datasheet for this device specs the short circuit current limit as 500mA typ, however I don't see anywhere that describes the limiting behavior. Is it brickwall or foldback?
Michael
Part Number: LP5907
Michael
Hi Michael,
The internal test data that I can locate shows Vout decreasing in value as you increase the load current (above current limit). This emulates a foldback current limit and not a brickwall.
Stephen
Thanks for the reply Stephen. Are you able to share any of this data? I'm surprised there's no information in the datasheet on the behavior.
Michael
Hi Michael,
I was just in the process of updating my reply. I realized that the test data I was reviewing used a customer specific circuit and I would not count on that emulating the current limit. Let me see if I can locate something more specific that I can share, if not, let me see if we can measure something for you. Give me 2-3 business days to respond.
Stephen
Hi Michael,
Looks like it is more of a brick wall current limit than foldback. Sorry for the confusion. Here is some test data using a 2.7V output version of this LDO that we had readily available in our office.
Stephen
Thanks Stephen! Do you have any information on the recovery behavior? Is there any kind of internal delay in voltage regulation once the overcurrent condition is gone?
It's an older part, so there might be a delay in recovery. We can measure it and see what happens. Please give us a few business days to get that measurement.
Stephen
Hello Michael,
I have taken a recovery picture from current limit on the LP5907.
As you can see recovery is almost instantly out of current limit.
Hannah
