Hi ,
Is this document also applicable to LCOS Panel?
use TCON to control synchronization with images? Thanks
Hi ,
Yes. It's the same principle.
BR, Gracie
Hi Mars,
Actually I never heard of LCOS before and I just searched for it. I thought it was something just like upgrade of TFT-LCD. Is this used for automotive?
BR, Gracie
Hi Gracie,
The structure is slightly different. It is mainly used in automotive and medical applications, and is also used in AR/VR..
Hi Mars,
Thanks for sharing with me. I am not familiar with this panel. Do you also have the requirement of local dimming? Then maybe TCON is the main problem here. But where will the LED driver be? on the same board of LED?
BR, Gracie
Hi Gracie,
Yes, there are currently customers need to develop local dimming products with LCOS panels. We currently don’t know how to synchronize the image and backlight. It seems that it should be implemented through TCON.
The LED driver will be a separate PCB connected to the LED board through a flexible cable. Is there any other information about local dimming can share? Thank you.
