Other Parts Discussed in Thread: BQ29209, BQ77915
Hello everybody.
I'm evaluation this application:
- battery powered board
- 4x 18650 cells
- single cells has PCM
- I need to put these cells in series
- BQ24735 for charger
- I've onboard microcontroller
Questions:
- is strictly necessary to do cells balancing with 18650? there's a simple IC like BQ29209 that do that for 4 cells?
- what happen if I don't balance cells? problem with operating time? danger behaviour of cells?
I two commercial application I retrofit I found 18650 (with single PCM every cell) placed in series without balance.
So I'm not sure if I need it or not
I didn't find simple balancers for 4 cells in TI portfolio. Something like BQ29209.
So I'm trying to design a MCU managed balancer. Here you are my draft.
I can read single cell voltage (here you don't see analog frontend) and I can apply a discharge resistor to any cell.
Thanks for any reply to my questions.
Stefano
