Hi Team,
I have three questions about current monitor and soft start question, could you help me?
1. In LM5066 datasheet it have accuracy when VIN-SENSE voltage = 50mV and =25mV, for lower voltage across shunt will have higher tolerance and we didn't have clear spec correct? Ex. CL connect to GND and 10mV tolerance will > 3% but didn't have spec.
2. If didn't reserve soft start circuit, is LM5066 have other way to adjust start-up slew rate?
3. May I know the reason why at lower voltage across Rshunt condition will have worse current monitor accuracy?
Roy
