hi, we are using R2 IC, unfortunately the Device Name in the data memory has a bug: bq34z100-G1 it stays old version. We did try it on two lots:
34Z100
31KG4
CFG2
factory FW 0x0201
34Z100
26KG4
AN66
factory FW 0x0201
34Z100
31KG4
CFG2
factory FW 0x0201
34Z100
26KG4
AN66
factory FW 0x0201
Hey Tomasz,
You are able to program the correct firmware from the product page. https://www.ti.com/product/BQ34Z100-R2
Nick Richards
hi, FW is fine, it seems that somebody did forget to change default flash Device Name when moving form G1 to R2, you should upgrade production dataset
Hey Tomasz,
Oh ok, I misunderstood what you stated before. We will make a note of this. Thank you!
Nick Richards
