I want to drive one MOSFET to fix the BUS voltage by the UCC27714. This has two input pins HI and LI working with two PWM signals like a datasheet circuit. In my case, I have just one PWM signal that I applied to the HI and I put LI in floating . Then LO was connected to the GND. Is this right for a single input for this IC (schematic attached)?
Thank you in advance.
Leila
