Other Parts Discussed in Thread: BQ25172,
We are looking for a stand-alone IC solution for a low power 3S NiMH battery solar charger and from the looks of it, out of 300+ ICs that TI is offering, only very few are tailored for NiMH chemistry (BQ25172 in particular) and none of those supports any MPPT-like or VINDPM functionality.
Since 3-cell in series NiMH battery is very close in charge profile and voltage requirements of 1S LiIon/LiPo cell, can we use BQ25185 for this purpose?
Our plan is to create a Solar Charge Controller that would charge ~1000mAh battery at around 100mA, and best we found so far is this IC. Assuming we set proper voltage cut-off and charge current limit, are there any cons of using this IC for this application? We plan on using 1-3W 6V solar panels.
Thank you in advance!
