Hi team,
I forget where I found the document, but I think it says that the CBULK must be an electrolytic capacitor, and if a ceramic capacitor is used, it should be connected in series with a 1 ohm resistor.
What is the reason for this?
Also, in the related thread it says that ceramic capacitors can be used at low power levels, but if the application is 8W or less can ceramic capacitors be used and no series resistors are needed?
Thanks.
