Other Parts Discussed in Thread: BQ25600, BQ25601, BQ25600C, BQ25600D, BQ25606, BQ25601D
BQ2560x FAQ Home Page
This is the home page for common questions in relation to the BQ25600, BQ25600D, BQ25600C, BQ25601, BQ25601D, and BQ25606.
FAQs
Charge regulation:
- Why does ICHG reduce when reaching the maximum duty cycle?
- Why does ICHG reduce during the input current DPM (Dynamic Power Management) or the input voltage DPM?
System regulation:
- Why VSYS does not start up normally when there is a loading on the SYS and the battery is not present?
- Why does the LED connected to STAT pin flashes and the SYS voltage unstable when battery is not connected?
Battery temperature feedback and charging effects
- How does JEITA apply to the BQ25600, BQ25600D, BQ25601, BQ25601D, and BQ25606 as it relates to charge voltage and charge current?
- How do I set the temperature range I desire using the TS pin on BQ2560x?
Safety features:
- How does the charge safety timer work?
- Why do I have to read the fault status twice to see the cleared fault on BQ2560x?
OTG function:
Ship mode + /QON Pin:
- What is ship mode and how do I enter and exit it in BQ2560x?
- What is the function of the /QON pin on BQ2560x?
Miscellaneous:
Software:
Application Notes
- Selection of Single-Cell Buck Narrow VDC Switching Battery Chargers
- Dynamic Power-Path Mgmt & Dynamic Power Mgmt (Rev. A)
- Battery Charger Overload Protection in Boost Mode Operation
- USB D+/D- Input Current Limit Detection
- Designing Standalone Single Cell 3-A Charger with bq25606
Other Documentation
- How to choose the right charger for industrial batteries
- Powering the smart home with a simple charger
Datasheets
- BQ25601 I2C Controlled 1-Cell 3-A Buck Battery Charger for High Input Voltage and NVDC Power Path Management datasheet (Rev. A)
- BQ25601DI2C Controlled 3-A Single-Cell Battery Charger With USB Charger Detection for High Input Voltage and Narrow Voltage DC (NVDC) Power Path Management datasheet (Rev. B)
- BQ25600 and BQ25600D I2C Controlled 1-Cell 3.0-A Buck Battery Chargers for High-Input Voltage and NVDC Power Path Management datasheet (Rev. B)
- BQ25606 Standalone 1-Cell 3.0-A Buck Battery Charger datasheet (Rev. C)
EVM User Guides
