TUSB1046EVM: Original project files for the EVM <INT053 Rev F>
Part Number: TUSB1046EVM
Other Parts Discussed in Thread: TUSB1146EVM
Could you send me a original project file (.pjt) and binary file (.bin)?
This EVM's version is Rev.F, so please send me those fies for TPS65987DDHRSHR.
Thank you for your support.
  • Hi Yusuke,
    Here's the .bin file for that EVM:
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/196/INT053D_5F00_Firmware.bin
    I'm not sure whether we have the .pjt file for this board, but I'll try to find this for you.
    Shane
  • Hello Shane,
    Thank you for sending bin file.
    My board revision is INT053F (Rev.F) and it seems that this bin version is INT053D (Rev.D),
    so I'm not sure it work but I'll try it.
    As for project file, it'll be very helpful if you send it to me.
  • Sorry, but it doesn't work.
    I confirmed default FW output VBUS 5V but this doesn't output VBUS.
    Could you send INT053F_Firmware.bin?
  • Hi Yusuke,
    The rev D firmware was the latest file uploaded for this board internally. That's why I sent it earlier.
    I see there was a change in the PD controller between rev D and rev F of this board that would require new .pjt and .bin files. I don't believe the new files were uploaded internally, so I'll need to make these for you. Please give me a few days to put these together and test them on one of the EVMs we have here.
    I'll update this thread with the new files as soon as possible (I would estimate Wednesday of next week at the latest). Thank you for bringing this to our attention.
    Shane
  • Hi Yusuke,
    I modified the firmware from our TUSB1146EVM board to match the PD controller pinout on the TUSB1046EVM. Here are the .pjt and .bin files:
    TUSB1046EVM_Firmware.pjt
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/196/TUSB1046EVM_5F00_Firmware.bin
    Can you try using these files on your board to see if they work?
    Shane
  • Thank you for your FW release.
    I confirmed it works without problem.
    Thank you for your support and I close this case.
