BQ34Z100-R2: Recommended tool for calibration and chemical ID identification
Part Number: BQ34Z100-R2
Other Parts Discussed in Thread: EV2400
Hello Folks,
Does TI provide a tool to perform following learning cycle on our custom battery pack?
https://www.tij.co.jp/jp/lit/an/slua903/slua903.pdf?ts=1697631565853
Basically a tool to which we connect out battery pack and it does all the required charging and discharging cycles and described in the document and generate a data in the format TI need to identify the chemical ID and calibrate the BQ34Z100-R2 Fuel gauge IC
Thanks!
  • Hey Vidit,
    You can use the EV2400 to communicate to the gauge and get all the necessary data. In terms of charging and discharging the battery, you can use a charger IC or you can use a power supply like a Keithley.
    Nick Richards
