TLV62568: Please give some suggestions for your help in reviewing the schematic design, thank you.
Part Number: TLV62568
  • Hi Xiaofu,
    Thanks for using E2E.
    Some comments to the schematic:
    • Please remove the 470p and 10R on the SW output because this have an influence on the general loop behavior.
    • The output capacitors should reduced to a max value of 47µF (2x 22µF), see data sheet.
    • The values for the feedback divider should be more in the range of 2x 100k to get a better efficiency.
    • Add a feed forward capacitor of 6.8pF to improve the loop bandwidth.
    I hope this helps to get a working schematic.
    Best regards, Sepp
