Part Number: TPS2117
Other Parts Discussed in Thread: LM66100,
Dear team,
My customer would like to use below concept. Their main concern is current consumption of battery < 1uA. Please review below concept and let me know your opinion.
<Case 1> normal operation. no load
1. VIN1(Primary) : 3.3V system voltage
2. VIN2(Secondary) : 2 ~ 3.3V battery voltage
At above condition, upper FET is turn on, lower FET is turn off .
In case of this configuration, what is current consumption of VIN2 battery? Max 0.08uA , VIN2 standby current(red box). is it right?
<case 2> system voltage lost , no load
1. VIN1(Primary) : 0V system voltage
At above condition, upper FET is turn off, lower FET is turn on.
In case of this configuration, what is current consumption of VIN2 battery? max 4.5uA , VIN2 quiescent current(Green box). is it right?
If the current consumption is over 1uA under both case, the customer can't use this concept. Is there any recommend concept to satisfy customer requirement?
Thank you.
