We have been using BQ25895 and has been performing well.
We just noticed an issue where BQ25895 does not charge after a certain event. The issue is further explained below as steps.
Note: Tried to simulate this behaviour by heating the NTC manually
1. Charger is Connected, then BQ25895 Starts Charging, SYS works perfectly fine.
2. BQ25895 Finds NTC Fault -> Charging LED Blinks.
3. When Charger is Removed, SYS turns off. This implies that SYS is not powered by BAT anymore.
4. Connecting charger again will only turn on SYS. BQ25895 doesn't continue charging even when NTC reached room temperature. Removing the charger turns off SYS.
The only way to get past this is to replug the battery, which fixes the issue. This is not possible in any application due to inconvenience. We tried to reset the registers to default by utilising the reset register/bit. That didn't help either. Is there any specific register to restart charging when charger is plugged back in? (assuming BQ25895 turned off BAT Path & NTC temperature reached normal)
Did notice that, this behaviour only happens once in a while. When trying to recreate the same issue (heating NTC), it did require a few attempts.
