TPS22976: Vbias and output discharge
Part Number: TPS22976
Hi Team,
in datasheet, there is below description, just wan to check output discharge circuit will only work when EN is low and Vbias is above recommended voltage? if only EN is low , Vbias is below recommended voltage, will output discharge circuit work? And what does it mean " for best results"? Thanks.
BRs
Given
