I want to know if I can enable, for example, Buck 1 with a GPIO input. The idea is that during the power-on sequence GPIO1 enables an external buck converter and the power-good signal from this regulator enables the PMIC's Buck 1 regulator using GPIO2 as an input. Maybe reading the status from GPIO2 I will be able to change the buck's registers and enable it.
Thank you for the support.
Jorge Cruz
