Hi TI engineers,
I am using UCC15240-Q1 on my hardware but it doesn't output desired voltage. The designed outputs are VDD-VEE = 25 V and COM-VEE = 5 V.
The below picture shows waveforms of VDD-VEE(yellow) and COM-VEE(cian) at starting-up.
COM-VEE does not stay around 5 V and goes upto 11 V, then decreases. VDD-VEE stays around 25 V for a while, then decreases.
I read "11.3.2 Output Voltage Soft Start" in the data sheet, but didn't understand what causes this problem.
Could you help me figuring out what is going on here? Thank you.
