Part Number: TPS25750
Other Parts Discussed in Thread: TPS25751
I am curious how the loading of the patch bundle works with the TPS25750. I understand that you can program it using the I2Cs from a processor, but can the TPS25750 then proceed to program the EEPROM using it's I2Cm or do we need to program the EEPROM in advance?
Is the configuration kept until the power is cut completely when programmed from the I2Cs? Does that mean that the USB-PD controller goes into a default mode until it is set-up correctly?
Thank you and have a nice day,
Marc-Antoine Dion
