I'm trying to understand the function of the /TE signal.In the datasheet it describes it as a Timer Enable signal that is "used to disable or enable the fast-charge timer" In the EVM documentation t is described as Termination Enable signal
Nowhere in the datasheet flow diagram can I make sense of the impact of the /TE signal on charging behavior.
Can anyone explain the impact of this signal on charge behavior? Or should I just leave it tied to ground?
