Other Parts Discussed in Thread: TPS92519-Q1
Hi.
In TPS92520-Q1 datasheet we have:
COMP pins are connected to signal ground.
But in EVAL modules (TPS92520-Q1 LaunchPad-Controlled, ECUEvaluation Module, and also in TPS92519-Q1 Evaluation Module) I see that COMP capacitors are connected directly to nearest ground plane, which is much more closer to power PGND pins.
My question is, how much important is to proper decouple COMP pins to signal ground?
If necessary, I can route independent GND tracks directly from GND pins (7 and 10) to COMP capacitors.
Thanks in advance!
