Other Parts Discussed in Thread: LM3435
Hi all.
So this post is basically a post where I need ur feedback to tell me if I made the right choice of an LED driver IC.
I purchased a RGBW led. I would like to control the brightness and color of this LED at its max voltage and current values; within an Arduino.
After a lot of digging around I came to the conclusion that the LM3464MH/NOPB is my best option. ( https://www.ti.com/product/LM3464 )
I would appreciate it if someone could tell me if I chose a 'good enough' driver IC.
The datasheet for the led is at https://www.ledsupply.com/content/pdf/XLampXML_Color.pdf
Below are the main characteristics of the led.
Here are my requirements:
1) I need to be able to control the brightness of each LED, with an Arduino; up to its full brightness! ( I feel this is possible cause this driver is rated for a max Vout of 80V and 4 Amps. )
2) I need to be able to control all 4 colors with an Arduino. ( I feel this is possible since this IC has 4 channels. )
Can someone tell me if my choice of a driver will work out for me?
Ty!
