LM7480-Q1: How to keep DGATE active during EN/UVLO pin is low
Part Number: LM7480-Q1
We need an always-on output to charge our battery pack and another output to supply our system, which is controlled by the EN/UVLO pin. We plan to use common drain topology; the battery pack will be connected to the drain pins, but we need to keep DGATE in the on state even when the EN/UVLO pin is low. You mentioned that "If V(ENF) < V(EN/UVLO) < V(UVLOF) then only HGATE is disabled disconnecting the load from the supply, DGATE remains ON". Are there any simple ways to keep that pin between V(ENF) and V(UVLOF)?"
