Hi team,
The accuracy of output V is +/- 0.8% with +/- 1% tolerance VSET resistor.
If this resistor is changed to tolerance +/- 0.1% one, will accuracy of output V improve?
Goto
Hi team,
Goto
Hi Goto
The VSET resistor vs output V tolerance, they are independent. Tighter tolerance VSET R will not increase output V tolerance.
VSET resistor is read at start up, current pulse that generates a voltage that is measured. The voltage will correspond to 1 of 8 preset voltages.
More of a digital or Bin system, not so much analog.
