We want to verify:The relationship between FCC and Qmax predicted by Fuelgauge for batteries with different aging levels, provided that the Fuelgauge learning conditions are met.
In order to speed up the verification, the ‘Max Qmax Change’ register needs to be adjusted. The default value of 20% is currently used and needs to be changed to 50%.
Q1:Is it necessary to modify other related registers when modifying ‘Max Qmax Change’ register? Which registers are they? What are the values of these related registers?
Q2: What is the effect of modifying the ‘Max Qmax Change’ register on the Fuelgauge algorithm? What is the basis of the effect?Please help me to list them in detail!
Q3:What is the effect of modifying ‘Max Qmax Change’ register on Qmax measurement? What is the basis of the effect? Please help me to list them in detail!
Q4:What is the effect of modifying ‘Max Qmax Change’ register on FCC prediction? What is the basis of the effect? Please help me to list them in detail!
我们要验证:不同老化电池,Fuelgauge预测的FCC和测量的Qmax之间的对应关系。
为了加快验证,需要调整"Max Qmax Change"寄存器。当前使用的默认值20%,需要修改到50%。
请问:
Q1:修改“Max Qmax Change”寄存器,是否要同步其它关联寄存器?分别是什么?要修改为什么值?
Q2:修改“Max Qmax Change”寄存器,对电量计的算法,有什么影响?影响的依据是什么?请帮忙详细罗列。
Q3:修改“Max Qmax Change”寄存器,对Qmax的测量有哪些影响?影响的依据是什么?请帮忙详细罗列。
Q4:修改“Max Qmax Change”寄存器,对FCC的预测有哪些影响?影响的依据是什么?请帮忙详细罗列。
