Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPS6594-Q1: Power up fail at low temp
Part Number: TPS6594-Q1
Dear expert,
Customer use TPS65941213 + LP876411B4RQKRQ1.
There is one pcs system cannot power up at -20C. Need your guidance here:
Below is TPS6594 VCCA_3V3 and Buck3 output. After several retry fail, they shut down VCCA_3V3.
Below is TPS6594 and Buck3 output zoom in.
Below is TPS6594 VCCA_3V3 and LDO
Below is TPS6594 VCCA_3V3 and LDO zoom in:
Below is LP8764 Vout and GPIO 10 output
Below is TPS6594 register dump:
DEV_REV
0x01
1
0
0
0
0
0
1
0
NVM_CODE_1
0x02
0
0
0
1
0
0
1
1
NVM_CODE_2
0x03
0
0
0
0
0
1
0
0
BUCK1_CTRL
0x04
0
0
1
0
0
0
0
0
BUCK1_CONF
0x05
0
0
1
0
1
0
1
1
BUCK2_CTRL
0x06
0
0
1
0
0
0
0
0
BUCK2_CONF
0x07
0
0
1
0
1
0
1
1
BUCK3_CTRL
0x08
0
0
1
0
0
0
0
0
BUCK3_CONF
0x09
0
0
1
0
1
1
0
1
BUCK4_CTRL
0x0A
0
0
1
0
0
0
0
0
BUCK4_CONF
0x0B
0
0
1
0
1
0
1
1
BUCK5_CTRL
0x0C
0
0
1
0
0
0
0
0
BUCK5_CONF
0x0D
0
0
0
1
1
0
1
1
BUCK1_VOUT_1
0x0E
0
0
1
1
0
1
1
1
BUCK1_VOUT_2
0x0F
0
0
1
1
0
1
1
1
BUCK2_VOUT_1
0x10
0
0
1
1
0
1
1
1
BUCK2_VOUT_2
0x11
0
0
1
1
0
1
1
1
BUCK3_VOUT_1
0x12
1
1
1
1
1
1
0
1
BUCK3_VOUT_2
0x13
1
1
1
1
1
1
0
1
BUCK4_VOUT_1
0x14
0
1
0
0
0
0
0
1
BUCK4_VOUT_2
0x15
0
1
0
0
0
0
0
1
BUCK5_VOUT_1
0x16
1
0
1
1
0
0
1
0
BUCK5_VOUT_2
0x17
1
0
1
1
0
0
1
0
BUCK1_PG_WINDOW
0x18
0
0
0
1
1
0
1
1
BUCK2_PG_WINDOW
0x19
0
0
0
1
1
0
1
1
BUCK3_PG_WINDOW
0x1A
0
0
1
1
1
1
1
1
BUCK4_PG_WINDOW
0x1B
0
0
0
1
1
0
1
1
BUCK5_PG_WINDOW
0x1C
0
0
0
1
1
0
1
1
LDO1_CTRL
0x1D
0
0
1
0
0
0
0
0
LDO2_CTRL
0x1E
0
0
1
0
0
0
0
0
LDO3_CTRL
0x1F
0
0
1
0
0
0
0
0
LDO4_CTRL
0x20
0
0
1
0
0
0
0
0
LDOINT_CTRL
0x21
0
0
0
0
0
0
0
0
LDORTC_CTRL
0x22
0
0
0
0
0
0
0
0
LDO1_VOUT
0x23
0
0
1
1
1
0
0
0
LDO2_VOUT
0x24
0
0
1
1
1
0
0
0
LDO3_VOUT
0x25
0
0
0
1
0
0
0
0
LDO4_VOUT
0x26
0
0
1
1
1
0
0
0
LDO1_PG_WINDOW
0x27
0
0
0
1
1
0
1
1
LDO2_PG_WINDOW
0x28
0
0
0
1
1
0
1
1
LDO3_PG_WINDOW
0x29
0
0
0
1
1
0
1
1
LDO4_PG_WINDOW
0x2A
0
0
0
1
1
0
1
1
VCCA_VMON_CTRL
0x2B
0
0
1
0
0
0
0
1
VCCA_PG_WINDOW
0x2C
0
0
1
1
1
1
1
1
GPIO1_CONF
0x31
0
0
1
0
0
0
0
0
GPIO2_CONF
0x32
0
1
0
0
0
0
0
0
GPIO3_CONF
0x33
0
1
0
1
1
0
0
0
GPIO4_CONF
0x34
1
1
0
0
1
0
0
0
GPIO5_CONF
0x35
0
0
1
0
1
0
0
1
GPIO6_CONF
0x36
0
0
1
0
1
0
0
0
GPIO7_CONF
0x37
0
0
1
1
1
0
0
0
GPIO8_CONF
0x38
0
1
1
1
1
0
0
0
GPIO9_CONF
0x39
0
0
0
0
0
0
0
1
GPIO10_CONF
0x3A
1
1
0
1
1
0
0
0
GPIO11_CONF
0x3B
0
1
0
0
0
0
1
1
NPWRON_CONF
0x3C
0
0
0
1
1
0
0
1
GPIO_OUT_1
0x3D
0
0
0
0
0
0
0
0
GPIO_OUT_2
0x3E
0
0
0
0
0
0
0
0
GPIO_IN_1
0x3F
0
0
0
0
0
0
0
0
GPIO_IN_2
0x40
0
0
0
0
1
0
0
0
RAIL_SEL_1
0x41
0
1
0
1
1
0
1
0
RAIL_SEL_2
0x42
1
0
0
1
0
1
1
0
RAIL_SEL_3
0x43
0
0
0
0
0
1
0
1
FSM_TRIG_SEL_1
0x44
0
0
0
1
1
1
1
0
FSM_TRIG_SEL_2
0x45
0
0
0
0
0
0
0
1
FSM_TRIG_MASK_1
0x46
0
1
0
1
0
1
0
1
FSM_TRIG_MASK_2
0x47
0
1
0
1
0
1
0
1
FSM_TRIG_MASK_3
0x48
0
0
0
1
0
1
0
1
MASK_BUCK1_2
0x49
0
0
0
0
0
0
0
0
MASK_BUCK3_4
0x4A
0
0
0
0
0
0
0
0
MASK_BUCK5
0x4B
0
0
0
0
0
0
0
0
MASK_LDO1_2
0x4C
0
0
0
0
0
0
0
0
MASK_LDO3_4
0x4D
0
0
0
0
0
0
0
0
MASK_VMON
0x4E
0
0
0
0
0
0
0
0
MASK_GPIO1_8_FALL
0x4F
1
1
1
1
1
1
1
1
MASK_GPIO1_8_RISE
0x50
1
1
1
1
1
1
1
1
MASK_GPIO9_11
0x51
0
0
1
1
1
1
1
1
MASK_STARTUP
0x52
0
0
0
1
0
0
0
1
MASK_MISC
0x53
0
0
0
0
0
0
1
0
MASK_MODERATE_ERR
0x54
0
0
1
0
0
0
0
0
MASK_FSM_ERR
0x56
0
0
0
0
0
0
0
0
MASK_COMM_ERR
0x57
0
0
0
0
0
0
0
0
MASK_READBACK_ERR
0x58
0
0
0
0
0
0
0
0
MASK_ESM
0x59
0
0
1
1
1
1
1
1
INT_TOP
0x5A
1
0
1
1
1
0
1
1
INT_BUCK
0x5B
0
0
0
0
0
0
1
0
INT_BUCK1_2
0x5C
0
0
0
0
0
0
0
0
INT_BUCK3_4
0x5D
0
0
0
0
0
0
1
0
INT_BUCK5
0x5E
0
0
0
0
0
0
0
0
INT_LDO_VMON
0x5F
0
0
0
0
0
0
0
1
INT_LDO1_2
0x60
0
0
0
0
0
1
0
0
INT_LDO3_4
0x61
0
0
0
0
0
0
0
0
INT_VMON
0x62
0
0
0
0
0
0
0
0
INT_GPIO
0x63
0
0
0
0
0
0
0
0
INT_GPIO1_8
0x64
0
0
0
0
0
0
0
0
INT_STARTUP
0x65
0
0
0
0
0
0
1
0
INT_MISC
0x66
0
0
0
0
0
0
0
1
INT_MODERATE_ERR
0x67
0
0
0
0
1
0
0
0
INT_SEVERE_ERR
0x68
0
0
0
0
0
0
0
0
INT_FSM_ERR
0x69
0
0
0
0
0
1
1
0
INT_COMM_ERR
0x6A
0
0
0
0
0
0
0
0
INT_READBACK_ERR
0x6B
0
0
0
0
0
0
0
0
INT_ESM
0x6C
0
0
0
0
0
0
0
0
STAT_BUCK1_2
0x6D
0
0
0
0
0
0
0
0
STAT_BUCK3_4
0x6E
0
0
0
0
0
0
0
0
STAT_BUCK5
0x6F
0
0
0
0
0
0
0
0
STAT_LDO1_2
0x70
0
0
0
0
0
0
0
0
STAT_LDO3_4
0x71
0
0
0
0
0
0
0
0
STAT_VMON
0x72
0
0
0
0
0
0
0
0
STAT_STARTUP
0x73
0
0
0
0
0
0
1
0
STAT_MISC
0x74
0
0
0
0
0
0
0
0
STAT_MODERATE_ERR
0x75
0
0
0
0
0
0
0
0
STAT_SEVERE_ERR
0x76
0
0
0
0
0
0
0
0
STAT_READBACK_ERR
0x77
0
0
0
0
0
0
0
0
PGOOD_SEL_1
0x78
0
0
0
0
0
0
0
0
PGOOD_SEL_2
0x79
0
0
0
0
0
0
0
0
PGOOD_SEL_3
0x7A
0
0
0
0
0
0
0
0
PGOOD_SEL_4
0x7B
0
0
0
0
0
0
0
0
PLL_CTRL
0x7C
0
0
0
0
0
0
0
0
CONFIG_1
0x7D
0
0
0
0
0
0
0
0
CONFIG_2
0x7E
0
0
0
0
0
0
0
0
ENABLE_DRV_REG
0x80
0
0
0
0
0
0
0
0
MISC_CTRL
0x81
0
0
0
0
0
1
0
0
ENABLE_DRV_STAT
0x82
0
0
0
1
1
0
0
0
RECOV_CNT_REG_1
0x83
0
0
0
0
1
1
1
1
RECOV_CNT_REG_2
0x84
0
0
0
0
1
1
1
1
FSM_I2C_TRIGGERS
0x85
0
0
0
0
0
0
0
0
FSM_NSLEEP_TRIGGERS
0x86
0
0
0
0
0
0
0
0
BUCK_RESET_REG
0x87
0
0
0
1
1
1
1
1
SPREAD_SPECTRUM_1
0x88
0
0
0
0
0
0
0
0
FREQ_SEL
0x8A
0
0
0
0
0
0
0
0
FSM_STEP_SIZE
0x8B
0
0
0
0
1
0
1
1
LDO_RV_TIMEOUT_REG_1
0x8C
1
1
1
1
1
1
1
1
LDO_RV_TIMEOUT_REG_2
0x8D
1
1
1
1
1
1
1
1
USER_SPARE_REGS
0x8E
0
0
0
0
0
0
0
0
ESM_MCU_START_REG
0x8F
0
0
0
0
0
0
0
0
ESM_MCU_DELAY1_REG
0x90
0
0
0
0
0
0
0
0
ESM_MCU_DELAY2_REG
0x91
0
0
0
0
0
0
0
0
ESM_MCU_MODE_CFG
0x92
0
0
0
0
0
0
0
0
ESM_MCU_HMAX_REG
0x93
0
0
0
0
0
0
0
0
ESM_MCU_HMIN_REG
0x94
0
0
0
0
0
0
0
0
ESM_MCU_LMAX_REG
0x95
0
0
0
0
0
0
0
0
ESM_MCU_LMIN_REG
0x96
0
0
0
0
0
0
0
0
ESM_MCU_ERR_CNT_REG
0x97
0
0
0
0
0
0
0
0
ESM_SOC_START_REG
0x98
0
0
0
0
0
0
0
0
ESM_SOC_DELAY1_REG
0x99
0
0
0
0
0
0
0
0
ESM_SOC_DELAY2_REG
0x9A
0
0
0
0
0
0
0
0
ESM_SOC_MODE_CFG
0x9B
0
0
0
0
0
0
0
0
ESM_SOC_HMAX_REG
0x9C
0
0
0
0
0
0
0
0
ESM_SOC_HMIN_REG
0x9D
0
0
0
0
0
0
0
0
ESM_SOC_LMAX_REG
0x9E
0
0
0
0
0
0
0
0
ESM_SOC_LMIN_REG
0x9F
0
0
0
0
0
0
0
0
ESM_SOC_ERR_CNT_REG
0xA0
0
0
0
0
0
0
0
0
REGISTER_LOCK
0xA1
0
0
0
0
0
0
0
0
USER_EE_CTRL_1
0xA2
0
0
0
0
0
0
0
0
USER_EE_CTRL_2
0xA3
1
0
0
0
0
0
0
0
SRAM_ADDR_CTRL
0xA4
0
0
0
0
0
0
0
0
RECOV_CNT_PFSM_INCR
0xA5
0
0
0
0
0
0
0
0
MANUFACTURING_VER
0xA6
0
0
0
0
1
0
0
0
CUSTOMER_NVM_ID_REG
0xA7
0
0
0
0
0
0
0
0
SOFT_REBOOT_REG
0xAB
0
0
0
0
0
0
0
0
RTC_SECONDS
0xB5
0
0
0
0
0
0
0
0
RTC_MINUTES
0xB6
0
0
0
0
0
0
0
0
RTC_HOURS
0xB7
0
0
0
0
0
0
0
0
RTC_DAYS
0xB8
0
0
0
0
0
0
0
1
RTC_MONTHS
0xB9
0
0
0
0
0
0
0
1
RTC_YEARS
0xBA
0
0
0
0
0
0
0
0
RTC_WEEKS
0xBB
0
0
0
0
0
0
0
0
ALARM_SECONDS
0xBC
0
0
0
0
0
0
0
0
ALARM_MINUTES
0xBD
0
0
0
0
0
0
0
0
ALARM_HOURS
0xBE
0
0
0
0
0
0
0
0
ALARM_DAYS
0xBF
0
0
0
0
0
0
0
0
ALARM_MONTHS
0xC0
0
0
0
0
0
0
0
0
ALARM_YEARS
0xC1
0
0
0
0
0
0
0
0
RTC_CTRL_1
0xC2
0
0
0
0
0
0
0
0
RTC_CTRL_2
0xC3
1
1
1
0
0
0
0
0
RTC_STATUS
0xC4
1
0
0
0
0
0
0
0
RTC_INTERRUPTS
0xC5
0
0
0
0
0
0
0
0
RTC_COMP_LSB
0xC6
0
0
0
0
0
0
0
0
RTC_COMP_MSB
0xC7
0
0
0
0
0
0
0
0
RTC_RESET_STATUS
0xC8
0
0
0
0
0
0
0
0
SCRATCH_PAD_REG_1
0xC9
0
0
0
0
0
0
0
0
SCRATCH_PAD_REG_2
0xCA
0
0
0
0
0
0
0
0
SCRATCH_PAD_REG_3
0xCB
0
0
0
0
0
0
0
0
SCRATCH_PAD_REG_4
0xCC
0
0
0
0
0
0
0
0
PFSM_DELAY_REG_1
0xCD
0
1
0
1
1
0
0
0
PFSM_DELAY_REG_2
0xCE
1
0
0
1
1
1
0
1
PFSM_DELAY_REG_3
0xCF
0
0
0
0
0
0
0
0
PFSM_DELAY_REG_4
0xD0
0
0
0
0
0
0
0
0
RTS_SPARE_REG
0xD1
0
0
0
0
0
0
0
0
CRC_CALC_CONTROL
0xEF
0
0
0
0
0
0
0
0
CRC_1
0xF0
0
0
0
1
0
1
1
1
CRC_2
0xF1
1
0
0
1
0
0
1
0
CRC_3
0xF2
0
1
0
1
0
0
0
0
CRC_4
0xF3
1
1
0
0
1
1
0
1
CRC_5
0xF4
1
1
1
0
0
0
0
0
CRC_6
0xF5
1
1
0
1
1
0
0
1
CRC_7
0xF6
1
0
1
1
1
0
0
1
CRC_8
0xF7
0
1
0
0
1
1
0
1
CRC_9
0xF8
1
0
0
1
1
0
1
0
CRC_10
0xF9
0
0
0
0
1
0
0
1
CRC_11
0xFA
0
1
1
0
1
0
1
1
CRC_12
0xFB
1
0
1
1
1
0
0
0
CRC_15
0xFE
1
1
1
0
0
0
1
0
CRC_16
0xFF
1
0
0
1
0
1
1
0
WD_ANSWER_REG
0x01
0
0
0
0
0
0
0
0
WD_QUESTION_ANSW_CNT
0x02
0
0
0
0
0
0
0
0
WD_WIN1_CFG
0x03
0
0
0
0
0
0
0
0
WD_WIN2_CFG
0x04
0
0
0
0
0
0
0
0
WD_LONGWIN_CFG
0x05
0
0
0
0
0
0
0
0
WD_MODE_REG
0x06
0
0
0
0
0
0
0
0
WD_QA_CFG
0x07
0
0
0
0
0
0
0
0
WD_ERR_STATUS
0x08
0
0
0
0
0
0
0
0
WD_THR_CFG
0x09
0
0
0
0
0
0
0
0
WD_FAIL_CNT_REG
0x0A
0
0
0
0
0
0
0
0
Below is LP8764 register dump:
NVM_CODE_1
0x02
1
0
1
1
0
1
0
0
NVM_CODE_2
0x03
0
0
0
0
0
0
0
0
BUCK1_CTRL
0x04
0
0
1
0
0
0
0
0
BUCK1_CONF
0x05
0
0
1
0
1
0
1
1
BUCK2_CTRL
0x06
0
0
1
0
0
0
0
0
BUCK2_CONF
0x07
0
0
1
0
1
0
1
1
BUCK3_CTRL
0x08
0
0
1
0
0
0
0
0
BUCK3_CONF
0x09
0
0
1
0
0
0
1
0
BUCK4_CTRL
0x0A
0
0
1
0
0
0
0
0
BUCK4_CONF
0x0B
0
0
1
0
0
0
1
0
BUCK1_VOUT_1
0x0E
0
0
1
1
0
1
1
1
BUCK1_VOUT_2
0x0F
0
0
1
1
0
1
1
1
BUCK2_VOUT_1
0x10
0
0
1
1
0
1
1
1
BUCK2_VOUT_2
0x11
0
0
1
1
0
1
1
1
BUCK3_VOUT_1
0x12
0
0
0
0
0
0
0
0
BUCK3_VOUT_2
0x13
0
0
0
0
0
0
0
0
BUCK4_VOUT_1
0x14
0
0
0
0
0
0
0
0
BUCK4_VOUT_2
0x15
0
0
0
0
0
0
0
0
BUCK1_PG_WINDOW
0x18
0
0
0
1
1
0
1
1
BUCK2_PG_WINDOW
0x19
0
0
0
1
1
0
1
1
BUCK3_PG_WINDOW
0x1A
0
0
0
0
0
0
0
0
BUCK4_PG_WINDOW
0x1B
0
0
0
0
0
0
0
0
LDOINT_CTRL
0x21
0
0
0
0
0
0
0
0
VCCA_VMON_CTRL
0x2B
0
0
1
0
0
0
0
1
VCCA_PG_WINDOW
0x2C
0
0
1
1
1
1
1
1
VMON1_PG_WINDOW
0x2D
0
0
0
0
0
0
0
0
VMON1_PG_LEVEL
0x2E
0
0
0
0
0
0
0
0
VMON2_PG_WINDOW
0x2F
0
0
0
0
0
0
0
0
VMON2_PG_LEVEL
0x30
0
0
0
0
0
0
0
0
GPIO1_CONF
0x31
0
0
0
0
0
0
0
1
GPIO2_CONF
0x32
0
0
0
0
0
0
1
1
GPIO3_CONF
0x33
0
0
0
1
1
0
0
0
GPIO4_CONF
0x34
0
0
0
1
1
0
0
0
GPIO5_CONF
0x35
0
0
0
1
1
0
0
0
GPIO6_CONF
0x36
0
0
0
1
1
0
0
0
GPIO7_CONF
0x37
0
0
0
1
1
0
0
0
GPIO8_CONF
0x38
0
0
1
0
0
0
0
0
GPIO9_CONF
0x39
0
0
1
0
0
0
0
0
GPIO10_CONF
0x3A
0
0
0
0
0
0
0
1
ENABLE_CONF
0x3C
0
0
0
0
0
0
0
0
GPIO_OUT_1
0x3D
0
0
0
0
0
0
0
0
GPIO_OUT_2
0x3E
0
0
0
0
0
0
0
0
GPIO_IN_1
0x3F
0
0
0
0
0
0
0
0
GPIO_IN_2
0x40
0
0
0
0
0
0
0
0
RAIL_SEL_1
0x41
0
0
0
0
1
0
1
0
RAIL_SEL_3
0x43
0
0
0
0
0
1
0
0
FSM_TRIG_SEL_1
0x44
0
0
0
1
1
1
1
0
FSM_TRIG_SEL_2
0x45
0
0
0
0
0
0
0
1
FSM_TRIG_MASK_1
0x46
0
1
0
1
0
1
0
1
FSM_TRIG_MASK_2
0x47
0
1
0
1
0
1
0
1
FSM_TRIG_MASK_3
0x48
0
0
0
0
0
1
0
1
MASK_BUCK1_2
0x49
0
0
0
0
0
0
0
0
MASK_BUCK3_4
0x4A
0
0
0
0
0
0
0
0
MASK_BUCK3_4
0x4A
0
0
0
0
0
0
0
0
MASK_VMON
0x4E
0
1
1
0
1
1
0
0
MASK_GPIO1_8_FALL
0x4F
1
1
1
1
1
1
1
1
MASK_GPIO1_8_RISE
0x50
1
1
1
1
1
1
1
1
MASK_GPIO9_10
0x51
0
0
0
1
1
0
1
1
MASK_STARTUP
0x52
0
0
0
1
0
0
1
0
MASK_MISC
0x53
0
0
0
0
0
0
1
0
MASK_MODERATE_ERR
0x54
1
0
0
0
0
0
0
0
MASK_FSM_ERR
0x56
1
0
0
0
0
0
0
0
MASK_COMM_ERR
0x57
1
0
1
0
0
0
0
0
MASK_READBACK_ERR
0x58
0
0
0
0
1
0
0
1
MASK_ESM
0x59
0
0
1
1
1
0
0
0
INT_TOP
0x5A
1
0
1
1
0
0
0
0
INT_BUCK
0x5B
0
0
0
0
0
0
0
0
INT_BUCK1_2
0x5C
0
0
0
0
0
0
0
0
INT_BUCK3_4
0x5D
0
0
0
0
0
0
0
0
INT_VMON
0x62
0
0
0
0
0
0
0
0
INT_GPIO
0x63
0
0
0
0
0
0
0
0
INT_GPIO1_8
0x64
0
0
0
0
0
0
0
0
INT_STARTUP
0x65
0
0
0
0
0
0
0
0
INT_MISC
0x66
0
0
0
0
0
0
0
1
INT_MODERATE_ERR
0x67
0
0
0
0
1
0
0
0
INT_SEVERE_ERR
0x68
0
0
0
0
0
0
0
0
INT_FSM_ERR
0x69
0
0
0
0
0
0
1
0
INT_COMM_ERR
0x6A
0
0
0
0
0
0
0
0
INT_READBACK_ERR
0x6B
0
0
0
0
0
0
0
0
INT_ESM
0x6C
0
0
0
0
0
0
0
0
STAT_BUCK1_2
0x6D
0
0
0
0
0
0
0
0
STAT_BUCK3_4
0x6E
0
0
0
0
0
0
0
0
STAT_VMON
0x72
0
0
0
0
0
0
0
0
STAT_STARTUP
0x73
0
0
0
0
0
0
0
0
STAT_MISC
0x74
0
0
0
0
0
0
0
0
STAT_MODERATE_ERR
0x75
0
0
0
0
0
0
0
0
STAT_SEVERE_ERR
0x76
0
0
0
0
0
0
0
0
STAT_READBACK_ERR
0x77
0
0
0
0
0
0
0
0
PGOOD_SEL_1
0x78
0
0
0
0
0
0
0
0
PGOOD_SEL_4
0x7B
0
0
0
0
0
0
0
0
PLL_CTRL
0x7C
0
0
0
0
0
0
0
0
CONFIG_1
0x7D
1
1
0
0
0
0
0
0
ENABLE_DRV_REG
0x80
0
0
0
0
0
0
0
0
MISC_CTRL
0x81
0
0
0
0
0
1
0
0
ENABLE_DRV_STAT
0x82
0
0
0
1
1
0
0
0
RECOV_CNT_REG_1
0x83
0
0
0
0
1
1
1
1
RECOV_CNT_REG_2
0x84
0
0
0
0
1
1
1
1
FSM_I2C_TRIGGERS
0x85
0
0
0
0
0
0
0
0
FSM_NSLEEP_TRIGGERS
0x86
0
0
0
0
0
0
0
0
BUCK_RESET_REG
0x87
0
0
0
0
1
1
1
1
SPREAD_SPECTRUM_1
0x88
0
0
0
0
0
0
0
0
FREQ_SEL
0x8A
0
0
0
0
0
0
0
0
FSM_STEP_SIZE
0x8B
0
0
0
0
1
0
1
1
USER_SPARE_REGS
0x8E
0
0
0
0
0
0
0
0
ESM_MCU_START_REG
0x8F
0
0
0
0
0
0
0
0
ESM_MCU_DELAY1_REG
0x90
0
0
0
0
0
0
0
0
ESM_MCU_DELAY2_REG
0x91
0
0
0
0
0
0
0
0
ESM_MCU_MODE_CFG
0x92
0
0
0
0
0
0
0
0
ESM_MCU_HMAX_REG
0x93
0
0
0
0
0
0
0
0
ESM_MCU_HMIN_REG
0x94
0
0
0
0
0
0
0
0
ESM_MCU_LMAX_REG
0x95
0
0
0
0
0
0
0
0
ESM_MCU_LMIN_REG
0x96
0
0
0
0
0
0
0
0
ESM_MCU_ERR_CNT_REG
0x97
0
0
0
0
0
0
0
0
REGISTER_LOCK
0xA1
0
0
0
0
0
0
0
0
USER_EE_CTRL_1
0xA2
0
0
0
0
0
0
0
0
USER_EE_CTRL_2
0xA3
1
0
0
0
0
0
0
0
SRAM_ADDR_CTRL
0xA4
0
0
0
0
0
0
0
0
RECOV_CNT_PFSM_INCR
0xA5
0
0
0
0
0
0
0
0
MANUFACTURING_VER
0xA6
0
0
0
0
1
0
0
0
CUSTOMER_NVM_ID_REG
0xA7
0
0
0
0
0
0
0
0
VMON_CONF
0xA8
0
0
0
0
0
0
0
0
INT_SPI_STATUS
0xA9
0
0
0
0
0
0
0
0
SOFT_REBOOT_REG
0xAB
0
0
0
0
0
0
0
0
STARTUP_CTRL
0xC3
1
1
1
0
0
0
0
0
SCRATCH_PAD_REG_1
0xC9
0
0
0
0
0
0
0
0
SCRATCH_PAD_REG_2
0xCA
0
0
0
0
0
0
0
0
SCRATCH_PAD_REG_3
0xCB
0
0
0
0
0
0
0
0
SCRATCH_PAD_REG_4
0xCC
0
0
0
0
0
0
0
0
PFSM_DELAY_REG_1
0xCD
0
0
0
0
0
0
0
0
PFSM_DELAY_REG_2
0xCE
0
0
0
1
1
1
0
1
PFSM_DELAY_REG_3
0xCF
0
0
0
0
0
0
0
0
PFSM_DELAY_REG_4
0xD0
0
0
0
0
0
0
0
0
CRC_CALC_CONTROL
0xEF
0
0
0
0
0
0
0
0
CRC_1
0xF0
0
1
0
0
1
1
0
1
CRC_2
0xF1
0
0
0
0
1
0
1
0
CRC_3
0xF2
0
1
0
1
1
0
1
0
CRC_4
0xF3
1
1
0
0
0
1
0
1
CRC_5
0xF4
1
1
0
0
1
0
0
0
CRC_6
0xF5
0
1
1
1
0
0
0
0
CRC_7
0xF6
1
0
0
0
1
1
1
1
CRC_8
0xF7
0
0
1
0
1
0
1
1
CRC_9
0xF8
1
1
1
1
1
1
1
0
CRC_10
0xF9
0
0
0
1
0
0
0
0
CRC_15
0xFE
0
1
0
0
1
0
0
0
CRC_16
0xFF
1
0
0
1
0
1
1
0
WD_ANSWER_REG
0x01
0
0
0
0
0
0
0
0
0x02
0
0
1
1
1
1
0
0
WD_WIN1_CFG
0x03
0
1
1
1
1
1
1
1
WD_WIN2_CFG
0x04
0
1
1
1
1
1
1
1
WD_LONGWIN_CFG
0x05
0
0
0
0
0
0
0
0
WD_MODE_REG
0x06
0
0
0
0
0
0
1
0
WD_QA_CFG
0x07
0
0
0
0
1
0
1
0
WD_ERR_STATUS
0x08
0
0
0
0
0
0
0
0
WD_THR_CFG
0x09
1
0
1
1
1
1
1
1
WD_FAIL_CNT_REG
0x0A
0
0
1
0
0
0
0
0
  • Hello Ryan,
    The register dump reads out an interrupt for BUCK3_UV and LDO1_SC on the TPS65941213.
    In your design is FB_B3 connected to VCCA?
    Can you provide zoomed in scope shot to see if VCCA drops at during the recovery attempts?
    How low does LDO1 drop to between each recovery attempt?
  • Michael,
    Sorry for late response. Customer did some test.
    Yes, FB_B3 connect to VCCA.
    There is some small drop for VCCA.
    Below is zoom in. You can see min voltage is 3.06V which doesn't reach VCCA_UV_THR(-10%)2.97V.
    And we measured a good board for comparison.
    Below is zoom in. Min is 3.0V
    And customer optimized VCCA voltage drop from 3.06V to 3.17V for bad board. But there is still the same phenomenon.
    Is there any suggestion?
    For LDO1_SC interrupt, I think it is might due to LDO Residual Voltage Checking for several times reboot in the experiments. Do you think so?
  • How confident are you in the accuracy of the o-scope? The VCCA_UV_THR is -9% to -11%, with -10% being the typical value for the setting. That means I expect the interupt to trigger between 2.937 to 3.003V. The deglitch is enabled, so it has to be below threshold for 20us.
    Can you use a bench top 3.3V power supply instead of the your on-board 3.3V regulator? Then control the voltage level to see when VCCA_UV triggers.
  • Hi Michael,
    Long time no talk, hope you are doing well! Rayn is OOO and I will help to follow this issue.
    I think it should be a device issue and I suggest letting customer ABA test for the next step. My analysis is below. Please correct me if you have more ideas.
    1. Customer use an external power 3.3V supply instead of the on-board pre-regulator. Issue is reproduced too.
         According to the scope shot,  the 3.3V has some drop and the min voltage is 3.13V. It is higher than the UV threshold.
    2. According to the PDN, BUCK3 monitor is enabled at 3.7ms after the GPIO9/10 rise. But the scope shot shows the power off happens about 8ms after that. I think UV detection does not need 8ms delay. There should some error internal the chip.
    B&R
    Lijia
  • 2. According to the PDN, BUCK3 monitor is enabled at 3.7ms after the GPIO9/10 rise. But the scope shot shows the power off happens about 8ms after that. I think UV detection does not need 8ms delay. There should some error internal the chip.
    That green channel in the scope shot shot does not show what is measured/monitored by FB_B3. Considering that it is 200mV/div and the speed that it ramps up and down, I think that is LDO3. LDO3 turns on at the 2.7ms mark of the TO_ACTIVE sequence and shuts down at the 2.5ms mark of the orderly shutdown sequence. Therefore, this scope capture doesn't show when PMIC saw the UV event.
    Please follow these experiment steps:
    1. Supply board with 3.36V to allow PMICs to power up.
    2. Clear interrupts on PMIC associated with start up.
    3. Place scope probe on nINT and nRSTOUT of TPS65941213. They should both be HIGH at this point.
    4. Slowly step down the VCCA supply in 5mV - 10mV steps until nINT and nRSTOUT both go low.
    5. Measure DC voltage of VCCA at this point.
  • Hi Michael,
    Customer ABA the device and the failure follows the device. The failed device is returned to TI.
    B&R
    Lijia
