The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS274C65: Ready Output: Push-Pull or why is resistor needed?
Part Number: TPS274C65
Hi TI Team
The #Ready pin can source current from Vdd it seams. The datasheet states in the pin description: "connect to GND pin of the IC with resistor".
This could mean that the pin is _not_ push-pull but rather an open source output (P-FET)?
Thanks and regards,
-Urs
