GPCCHEM: Cannot find suitable ID
Part Number: GPCCHEM
Hello Sir:
We have log as below.
7827.new.zip
But we didn't receive suitable ID.
Can you help us check what's wrong with this report?
new-report.zip
Looking forward your feedback.
Thanks a lot.
  • Hello Statham,
    I believe the issue is with how the battery was charged.
    We recommend charging the battery with a constant current followed by a constant voltage charge.
    Nick Richards
  • Hello Sir:
    We reupdate below parameters but still no CHEMID can be used.
    Would you please help us check it again?
    Thanks a lot.
    20240524.zip
    20240524-report.zip
  • Hey Statham,
    What is the battery you are using for this test. Can you send me the datasheet for your battery.
    Nick Richards
  • Hey Chen,
    Thank you for that. Are you discharging all the way down to the terminate voltage for the battery? I don't see this number specified in the file sent, but the battery is discharged down only to 2.3V which is the nominal voltage.
    Nick Richards
  • Hi Nick, thanks for your feedback.
    Because of  our active model of battery  is between 2.7V~2.3V, so we don't discharge down at the terminate voltage.
    About more battery information, please refer to below link.
    www.global.toshiba/.../combination.html
  • Hello Yuanlung,
    To use the GPCCHEM tool, you must discharge the battery down to the terminate voltage specified in the datasheet for the battery. This is crucial for the GPCCHEM tool to work properly.
    Nick Richards
  • Hi Nick,
    Please refer to attachments and provide suitable ID.
    ProcessingType = 2
    NumCellSeries = 1
    ElapsedTimeColumn = 0
    VoltageColumn = 1
    CurrentColumn = 2
    TemperatureColumn = 3
    2425.roomtemp_rel_dis_rel.csv
  • Hello Yuanlung,
    I see this support turned into an email support. We will continue the discussion through email.
    Nick Richards
