TPS3808-Q1: abnormal output on n_RESET pin
Part Number: TPS3808-Q1
Hi Expert,
We found a wired phenomenon on TPS3808-Q1, need your support to check the potential reason.
Below is screenshot for TPS3808-Q1 schematic. When SENSE=730mV, we can see n_RESET=1.2V if we add a 27k pull down resistor on it and we remove the R1994 to disconnect with other circuit.
n_RESET pin is open drain output, why it will have 1.2V even we add a pull down resistor on it?
Thanks!
Ethan Wen
