TPS629210: Current consumption of devices in low output current
Part Number: TPS629210
Customer want to know when the in the very light load(100uA), will the current consumption of TPS629210 be higher than the zero load or normal load? what is the pattern?
Do we have any data about the current consumption with the load change?
Yishan Chen
  • Hi Yishan,
    If customer choose Auto PFM/PWM mode, the current consumption of TPS629210 at 100uA would be higher than zeron load but lower than normal load.
    Below is the efficiency data, you can get current consumption with the load change from this.
    Colin
