Dear friend,
Customer made a PFC demp using UCC28180D. However, during the test, it was found that the PFC power tube and UCC28180D chip are easily burned when the power is turned on. It may burn out once every 30 times when the power is turned on. But once it is powered on, there is no problem and it can work normally.
The damaged chip looks like pins 7 and 8 are short-circuited, and pin 7 seems to be damaged as well.What may be the reason?
