BQ24296M: How to turn BMS output OFF, if I2C fails.?
Part Number: BQ24296M
We have used bq24296M as the BMS for a medical device. A host MCU controls the bq24296M via I2C. The whole power management in the system is done by bq24296M.
To turn OFF, the host MCU sends an I2C data to BMS which cuts off the entire power supply.
Now to turn ON again, a manual push button is present which controls the internal gate logic inside BMS which turns ON the device again.
The question is how to turn OFF the power out from BMS, if the I2C channel fails.?
  • Hello Arjun,
    Thank you for reaching out via E2E.
    In your description are you referring to use of the 'BATFET_Disable' bit in I2C REG07?
    Assuming 'BATFET_Disable' is the feature you are referencing in your question I2C is the only possible method to force BATFET off to disconnect power path from battery to SYS output.
    For your information the BATFET will turn off on its own if battery discharges below Vbat_dpl threshold (max 2.6V) located on datasheet page 7.
    Garrett
