Can the LDO or BULK be enabled respectivly and dynamically?i mean, if now the controller who uses TPS6521905-Q1 is running, can one of the bulk or LDO can be enabled/disabled and later disabled/enabled.
and in chapter 7.6 NVM Programming, it said that " The EEPROM of a device can only be programmed up to 1000 times. ", if we enabled/disable one bulk or LDO by write ENABLE_CTRL, we can only write 1000 times? or we can write ENABLE_CTRL many times , but can save the new values into the NVM memory 1000 times at most?
Thank you !
