I am using a BQ24600 device to charge Li-ion battery. However, when I do the calculations for the thermistor that is fitted to the pack, I get negative resistances for one or other of RT1 and RT2. The thermistor in question has a cold resistance of 25.3k and a hot resistance of 5.3k. The calculations come back as RT1 being 10.3k with RT2 being -210k.
I have checked this with the spreadsheet tool mentioned in other posts and get the same values. As I can not change the thermisor, my only option appears to be allowing the pack to charge at -5 degrees as the cold resistance (32k) gives positive results.
Any help would be greatly appreciated.
Neil
